Well if your happy with 35 mpg then you could get any metro they all get above that. I have an XFI and the noise inside is alittle loud but worth it I can get 50mpg with the gas all the way to the floor but most of the time I drive slow and get In the 60s. The 3cylinder 5 speed is the only way to go I think if you get a 3.79 or 3.59 trans you will lose fast take off speeds but will gain probably around 10mpg. The xfi cam or the custom one from 3tech helps with mpg and low end power so if going to a taller trans I would put one in. Obd1 or obd2 these cars are very simple and easy to work on after 96 the cars were a little heavier so they lose a little mpg but not much it really just depends on what you want. Good luck shopping.
Oh and powersteering in a geo wouldn't be worth it they are light and very easy to steer
