Old 05-27-2010, 02:36 PM   #168 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Originally Posted by Wonderboy View Post
Remember... we're looking at a CRX climate control system. The coolant flow to the heater core can be stopped. Whether it's advisable to ever do that given that metros don't have that option I don't know, but I'm inclined to think it will be alright.
Anyone have insight on these questions?
There are two possible issues with stopping the coolant flow through the heater core on a Metro engine. Not life or death issues, but not ideal either.
1. It acts as the main bypass when the thermostat is closed. You should still have the little hoses that go to the throttle body to act as a bypass. That might be enough.
2. You will lose the heat to the intake manifold when you have the climate control heat turned off.
I don't know when you should change the oil, but you'll hurt nothing by changing it too soon.
I wouldn't worry too much about the intake tube. WOT should be OK, just listen for pinging or other weird noises. Like your engine falling out!
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
