Old 05-27-2010, 02:49 PM   #169 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Originally Posted by Wonderboy View Post
No, my tachometer still thinks its looking at a 4cyl Still have the XFi trans. BTW, anyone know if my speedo is affected by this? The Geo speedo cable fit directly on to the back of the CRX cluster. I don't know exactly how it works, but something tells me it should be correct and I don't have to do anything to get it accurate. While driving along it seems reasonable...
Didn't I see a GPS in your Civic at the GGP? Won't that check your speedometer accuracy? The speedo cable is driven by the differential carrier, so the final drive has no effect on the speedometer. But tire size [i]does[/] make a difference. I assume you're not using 145/80-12" tires on your CRX? The 1995+ Metros and Swifts had tires the same diameter as the CRX, so you might be better off using the speedo cable gear from one of those. I think there might be a one or two tooth difference between them. But I'd check how far off the speedo is before changing any parts.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
