Old 05-27-2010, 03:12 PM   #6 (permalink)
jamesqf
Originally Posted by RobertSmalls View Post
The DC/DC converter runs until the high voltage battery is almost empty, then it thankfully shuts off and allows the 12V battery to deplete itself.
Actually, it doesn't work that way, at least in my experience. If you have ignition or ACC on, the 12-volt battery can drain even though the IMA battery stays fully charged, at which point you can't start the car even by push-starting.
That's also a reason to keep an eye on the state of the 12-volt. If it gradually goes bad, you won't notice in normal driving, until one night you see the DC/DC converter stops working, the engine starts misfiring, and you coast to a stop. New 12-volt battery, and problem goes away.
