Originally Posted by jason1973tl
Come on guys somebody is obviously being taken for a ride. I have a Trans am with wide low profile high performance tires on it. I am not sure they would even charge 1300 a tire for the tires on a Bugatti Veyron. I have had these kind of cars and been around them all my life. No body pays that much for a tire unless you are buying the best tires money can buy.
Actually, the tires on the veyron are more than $1300 each
It uses special Michelin PAX run flat tires, designed specifically to accommodate the Veyron's top speed, which reportedly cost $25,000 US per set
But if I'm not mistaken he is referring to $1300 per set of 4 tires, or $325 a piece. Still pricey, but more realistic
