How small is "small displacement"? I have PSA's (Citroën-Peugeot, also installed in Fords as the 1.6l TDCi) HDi turbodiesel: 1.6 liter, aluminum block, 4 cylinder, 16 valves. I believe the newer 2.0l 2.2l also has a 4v/cyl version.
I don't know about the 0.8l 3-cyl CDI diesel in the Smart ForTwo, but I think the 1.2l 3-cyl TDI, of Audi A2 and VW Lupo 3L fame, had 4v per cylinder.
EDIT: Checked on
Wikipedia: The VW 1.2 TDI has only 2 valves per cylinder, but it is aluminum and weighs only 100kg (220lbs).
EDIT#2: The
0.8l CDI also is aluminum and has 2v/cyl, but no info on how much it weighs.
What matters is
where you're going, not
how fast.
