well i'm running a pair of 800amp igbts. Now thats a fairly optimistic current rating taken at a junction temp of 25c. Its probably good for 500amps which is what i wanted. Version 2 should be 1000amp capable but is still undergoing tests.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
