Old 06-02-2010, 11:28 AM   #17 (permalink)
darcane
darcane's Avatar
Originally Posted by hat_man View Post
There is also a small factory "air deflector" under the front bumper. I was thinking about removing this and making a new, longer one that would reach lower to the ground. I have also thought about lowering the truck a couple of inches. Wouldn't this help with air under the truck and over the truck at the same time?
Also, my Ranger rides "downhill". It looks like it is "jacked-up" (at least that's what we called it when we were kids). Is there a way to level it out?
For your Ranger, there is a nearly free way to lower the rear:
General Tech
And you could always cut a coil off the front if your not adverse to doing so. With your goofy, twin I-beam front suspension, you can only lower a little bit before you start really messing up the camber.
A slight rake is generally good for aero.
Narrower tires aren't an option right now as I just bought the ones on there. I'd rather wear them out first and then switch. I do wonder how the narrow tires will handle in the snow we get in northern Illinios. Has anyone out there had any bad experiences with narrow tires in the snow?
I've driven in snow a lot, and all other things equal, narrower tires perform better in the snow. Every watched a WRC snow race? You'll notice that in addition to the several hundred studs (for ice), they use a very narrow tire (185 wide?) with an aggressive tread pattern which is excellent for snow.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
