Old 06-02-2010, 08:11 PM   #19 (permalink)
elhigh
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
Hey, if the leaf springs out back are bolted under the axle like on my truck, lowering the rear is a simple matter of just putting a block between the axle and the spring, and longer U-bolts. It's a snap, to a degree. If you're not moving too far, there shouldn't be any big problems with driveline angles or stuff like that, but it's something to keep an eye on.
