Old 06-03-2010, 02:36 AM   #12 (permalink)
mcrews
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
pete said: "[B] I figure the added wear on tranny and axles is easily offset by the reduction in rpms/engine life. [B]
The real concern is in the small stuff. bushings and brakes.
But with the majority of your driving being highway you probably don't need to worry
the tires weight about 3.5 lbs more and the 15 rims about 4lbs.
So you at 7lb x 4 = 28lb of moving extra weight.
the old set up was about 125lb moving and the new is around 148lbs.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
