06-03-2010, 09:18 PM
#24 (permalink)
Since you've raised the car slightly with the oversized tires, what about dropping it slightly to compensate?
I know others squirm when this technique is mentioned, but the old-school method of chopping off half a coil at each corner may work (depending on the spring / coil seat design).
I did see that you don't want a "lowered" ride, but returning to stock or slightly less may help slightly.
PS - the smoothies look great!
