Old 04-04-2008, 02:20 AM   #56 (permalink)
Chris D.
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Toyota Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Toyota Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
Your shadow should be pulling 28 - 32mpg EASILY..
its slightly lighter than your turbo coupe and they both have a turbo setup, but the shadow has the sohc 8v 2.5 while the turbo coupe has the 2.3, so it should even out..
If i'm able to pull low 30's in a 2.4 dohc 16valve truck while hauling a couple hundred pounds of headstones and cement, you should easily be able to smoke that..
Work on that shadow more..
