Old 06-03-2010, 10:04 PM   #27 (permalink)
pgmomni
Camry MPG Modder
Camry CE - '00 Toyota Camry CE
90 day: 36.18 mpg (US)
I may just go ahead and delete the right mirror...
The best way to improve the aero there is to reduce frontal area. I'm assuming you probably don't want to delete/replace with a large convex mirror inside.
Tasdrouille went with a half-size convex racing mirror on his Jetta on the driver's side. Decent compromise.
and add a blind spot mirror on the inside for the right side.
Left side a smaller racing mirror.
Need to think about it.
Going to move onto the underbelly. Lots to be done under there pretty easily in the front.
Will post some frontal pics from before I changed tires.
Need to discuss suggestions for air dam design.
tks
Pete
2000 Camry CE 5 speed 128+K. Best 37.0, Goal is to break thru 36 consistently(Attained). New Goal 38.
ScanGauge II, Unibrow(1 wiper) Air Intake, Mud flap delete, 3.5+" Front Spoiler, Full Moon Hubcaps(Lost). Upper Grille block. (New and improved Fall edition)
