what brand/model are they?
Originally Posted by AeroModder
I do my best to avoid potholes, but I regularly drive over railroad crossings. No panic stops.
They're the elongated bubbles. Also, by sidewall rating, do you mean load rating? If so, they're 91.
I should have got the road hazard warranty when I ordered them, even if it could be a defect in the tires.
If it looks like belt separation you have a decent chance at "defect" pro-rated replacement.
I mentioned the brake lockup skid because up until I did that my tires were OK.
Back when I had my 91' Toyota 1/2 Ton PU I had Michelin LT's. Expensive but worth it.
One time a local tire dealer talked me into some passenger tires on it as it was "just a toyota pu". About 1 week into the new tires I cranked it into a right turn and almost went off the road. Dealer got reamed by corporate and I got full towards the LT's.
Pete
2000 Camry CE 5 speed 128+K. Best 37.0, Goal is to break thru 36 consistently(Attained). New Goal 38.
ScanGauge II, Unibrow(1 wiper) Air Intake, Mud flap delete, 3.5+" Front Spoiler, Full Moon Hubcaps(Lost). Upper Grille block. (New and improved Fall edition)
