I have check again and I am not mistaken, the 12 volts is not there. Any of you can tell me if their ISO or CAN pin really produce 12 volts?
I think my pin of power and ISO are swapped because when I use a 9v battery to hijack Arduino I see it open but it can still connect so I am guessing it try to send/receive at the wrong pin (the 12 volts). I might try to swap those 2 pins tonight.
