Old 06-10-2010, 05:52 PM   #23 (permalink)
Big Dave
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
Locomotives can generate power for buildings.
1. Open building disconnect
2. Line up locomotives
3. Disconnect the rectifier (converts AC to DC)
4. Forget step 3 if the locomotive is new enough to use AC traction
motors
5. For older AC/DC locomotives, set to throttle 5. It gives you about 1.5 MW @ 460 volts, 55 Hz.
6. For newer locomotives, set the VFD at 60 Hz and run her WOT. You should get about 3 MW/unit @ 460 volts
Old hat to railroaders.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
The Following User Says Thank You to Big Dave For This Useful Post:
Bicycle Bob (06-11-2010)
