Old 06-12-2010, 01:03 AM   #46 (permalink)
steffen707
Originally Posted by dremd View Post
flywheel mass will play a VERY small role with acceleration at 1500 RPM's in 5th, at higher rpm's that's a different story.
You forgot you can downshift
Also after some online searching i've read multiple times that a stock civic is 18lbs, exedy's stock replacement is 16.6 lbs and the civic vx stock weight is 15lbs.
Hmmm, 16.6% reduction in weight from "non fuel economy" civics.
