06-12-2010, 01:33 AM
#41 (permalink)
i have only just started to play with pulse and glide, but certainly having better acceleration is going to be a plus once i swap to crx hf gearing where 60mph is like 1500rpm in 5th.
06-12-2010, 01:36 AM
#42 (permalink)
is bump starting when you pop it back into gear will doing pulse and gliding? I havn't heard of the term bump starting before. I could totally see where heavier is smoother, but again, MPG is main concern.
06-12-2010, 01:38 AM
#43 (permalink)
EV OR DIESEL
flywheel mass will play a VERY small role with acceleration at 1500 RPM's in 5th, at higher rpm's that's a different story.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
06-12-2010, 01:44 AM
#44 (permalink)
Bus - '94 Ford School Bus huge Stupid - '01 Chevy Blazer LS 90 day: 21.38 mpg (US) hawk - '00 Honda Superhawk
Originally Posted by dremd
Hey auto tech, Where did you get info on lighter flywheels + traction? I find it more difficult to launch cars with lightweight flywheels, but that could be a function of what clutch is typically attached (double and triple disc for us Supra guys).
I wish I could remember where, but the function is this: Wheel slip on take off (or in the case of a snowmobile track slip) is = to the excess in flyweight (including all rotational energy of engine parts) energy delivered. Less inertia in, less wheel slip out. If there is really good traction, you can run a heavier flywheel and maximize input energy into the launch.
06-12-2010, 02:00 AM
#45 (permalink)
EV OR DIESEL
Yes, put the transmission in gear, and let out the clutch to eliminate starter use.
****** opinion******
If your main concern is fuel efficiency at steady state 70 mph, it makes no difference.
If you are going to pulse and glide around 70 go with the lightweight.
If you are going to be operating at slower speeds where you are limited be "lugging" go with the heavier flywheel.
Since you already own the lightweight, are not concerned with smoothness (NVH) I'd lean toward running the lightweight, but the decision is yours
End Opinion
2016 Tesla Model X
2022 Sprinter
2012 Nissan LEAF SV
06-12-2010, 02:03 AM
#46 (permalink)
You forgot you can downshift
Also after some online searching i've read multiple times that a stock civic is 18lbs, exedy's stock replacement is 16.6 lbs and the civic vx stock weight is 15lbs.
Hmmm, 16.6% reduction in weight from "non fuel economy" civics.
06-12-2010, 02:06 AM
#47 (permalink)
EV OR DIESEL
I did not, I stated "
acceleration in 5th at 1500 rpm's
", yes the equations change dramatically when rpm's increase "
2016 Tesla Model X
2022 Sprinter
2012 Nissan LEAF SV
06-12-2010, 02:22 AM
#48 (permalink)
16.6% reduction in something that doesn't really matter. Another question, what is the difference between weight and inertia? Maybe we shouldn't be calling them heavy or light flywheels, but high and low inertia flywheels. Is there anything that you can tell about the inertia of the three from there weight?
06-12-2010, 02:39 AM
#49 (permalink)
EV OR DIESEL
Well, I believe that inertia is mass* velocity, so unless we define velocity . . .
But I know what you are talking about; moment of inertia/ rotational inertia, and you are correct, that is the important metric.
2016 Tesla Model X
2022 Sprinter
2012 Nissan LEAF SV
06-12-2010, 02:52 AM
#50 (permalink)
well, that mass*velocity is linear inertia. Distance from the center for a rotational object has to be considered. You could produce a flywheel that weighs 20lbs that has the same inertia as ones weigh 18, 15, or 5 lbs.
