Thanks for the welcomes and tips
Originally Posted by Daox
I'm sure you can do a few mods to it. Airing up the tires to max sidewall is quite an easy one.
I had them to something in between the car manufacturers specs and max sidewall, but I have maxed them out now
They are brand new Michelin Energy Savers, so they have rather low rolling resistance.
Originally Posted by Piwoslaw
Yeah, everyone says that in the beginning
OK, I have to admit, I just came home after visiting the hardware store, I bought some sheet metal and something to cut it with
Took a look under the car, and there, about a foot rear of the front tires, I found mudflaps, almost 20% of the car width EACH, hanging almost to the ground. I figure they are there to protect the floor (which is plywood). Also, there is a couple of transverse beams supporting the plywood (which is a little more than a foot wide, from the "frame beam" out), behind the mudflap. And if I fasten a little sheet metal, from the mudflap and about 3 feet back, this will cover it all, and there will be a flush surface between the side skirt and the "frame beam" instead of a ground-sweeping mudflap, a 3 inches deep hole and a couple of transverse beams
And the wood should be at least as good protected as well.
Try engine braking on the downhills.
Engine braking and DFCO is a well known concept already
Also trying to learn how much throttle I can give it in different speeds without the lock-up releasing. Can't wait for the ScanGauge to get some precision to this.
A grille block and a block heater since you live in a cold climate.
Remove any racks or railings from the roof, those hurt bad.
The car is equipped with a block heater, but unfortunately I don't have access to any outlet where I park. The car also has a Webasto gas heater, but that doesn't save much fuel, I guess
Roof racks are long gone, but the rails are still there. Haven't looked into removing them yet.
