06-17-2010, 12:50 AM
#11 (permalink)
P0300 is random misfire , find it with exhaust pressure pulses
GM has misfire counters in Enhanced data, there may be misfire counts present that are not high enough to code the system
so , no Code .
you will need a scan tool with Enhanced GM software , a generic scan tool can not view misfire counters .
and - there' s more
intake vacuum at hot idle should be around 20"
and
the needle must be steady smooth with zero flutter , if there is any flutter , your new used engine has a valve sealing problem
and
if there is a local shop that has Emisfire OR AceMisfireDetective
either of those systems can pick a misfire out of the exhaust pressure pulses synced to spark or IGT on any cylinder.
they work by looking for a vacuum pulse in the pressure pulses , if a cylinder did not fire or did not fire as strong as the rest of the cylinders , when the exhaust valve opens at about 150 degrees after TDC , there will be a Lower pressure or vacuum pulse added to the exhaust pulse train .
not too expensive to connect
i charge 1 hour of labor
the upper yellow trace is exhaust pressure pulses
you can see a regular dip down , a vacuum pulse , and i have overlayed a running compression waveform (720 degrees) below in yellow also with Exhaust valve open EVO time marked by the green cursors.
sync to the pink / red trace .
the software normally picks this out for the user , i just made this screen cap so people can see what the software uses to arrive at the misfiring cylinder
Both programs Emisfire and AMD work very well
Reason: i am from ny- the image was missing ?
