Old 06-17-2010, 03:44 AM   #24 (permalink)
Arragonis
The PRC.
Originally Posted by ShadeTreeMech View Post
It's the cetane booster what done it. The higher the cetane level the better the mpgs. I'd consider using it more regularly (like every tank full, if it's simply a cetane booster) if it doesn't raise the cost of a tank of fuel too much.
What was the capacity of the cetane booster? Kinda like adding a bit of fuel midtank, but the cetane booster did the job I'm sure.
Drat, I was hoping it was technique.
The only reason I got it instead of straight injector cleaner was because the booster with cleaner mixed in was on offer at my local Halfords and turned out cheaper by volume. I also just about had the right cash in my pocket vs the cleaner - I'm like Prince Charles in that I rarely carry cash...
I'll have to do the maths and work out if its worth it overall but off the top of my head it looks like it is. The cost for a tankfull treatment was about £3.99 which is less than I pay for a gallon of Diesel at UK prices and the extra distance is about 2 gallons worth estimating 50 mpg. So I would say yes.
Originally Posted by ECONORAM View Post
Arragonis, is that vehicle a stick shift? 60 mpg is pretty good. My old diesel VW Rabbit (Golf 1) would get 48-50 mpg (5sp). I used to run cetane boost through it also. I thought it helped...
Yep it is, specs are 6 speed manual, 1.9 TDi 130hp with lightened flywheel, SMF and uprated sachs clutch. The only other mod is my gaffer tape wrapped boost pipe which was leaking.
Like all moderns though its lardy, so being smaller than a Golf 1 its also heavier. If I can make my mind up whether its a permanent keeper I may start to lighten it - removing seats and so on.
