Old 06-20-2010, 02:53 PM   #534 (permalink)
electromike
Glad to see people are still hanging around these forms. Wow. I was suprised that September of 09 was the last time we updated the code for this project. I guess that shows that it works well!
I have recently had the check engine light on in my car. The code to retrieve the error codes did not work for reading it, but unfortunatley I changed two things at once.
The clear check engine code worked, but reading did not.
So now I can't test any changes to the code to see if it will display the proper MIL codes, since my MIL light is now off.
Does anyone have a car with their MIL on and is willing to try flashing a modified piece of code to see if it works? **it may erase your saved settings, back up your calibration data first!**
here is the file hxxp://dl.dropbox.com/u/5064541/obduino32K.pde let me know if it works, then i will finish fixing up the code.
