The injector can vary the amount of fuel delivered by something like 1500%
1500%? come on now. come back to earth like a carb jet that actually atomizes at the speed of sound...
it is no more than 100% of its given ability... where is the 1500 coming from?
it is clever trick with the maf, I could guess the o2 sensor makes up for actual density, restricted or not.
I wonder if my carb is 15 million percent. maybe 10 million.
from zero percent skip right past the 100 and make up numbers as I go along.
may as well add 3 times as much injection, double the valves, and increae fuel flow to 20 times that of a carb system..and pretend I am a hypermiler, with a 1500% throttle.
