Originally Posted by Old Mechanic
In my VX what you notice is the gearing is soo tall. The car will do 120 in 3rd. If you need to maintain speed up a grade in the VX you are better off in lean burn and 3rd gear than 5th gear where you would have to floor the car to maintain the grade.
I'm interested in researching this in my TDI a little more. The gearing in 6th is very high and I have experimenting with lugging in a high gear with as little throttle as possible to maintain speed and going into a lower gear and doing the same.
I haven't come up with a complete answer, sometimes the higher gear is better and sometimes the lower one is. I do the same route and try different things but its a toss up as to which one wins.
How does BSFC work for this ?
