Old 06-24-2010, 07:22 PM   #120 (permalink)
AeroModder
AeroModder's Avatar
Tank - '96 Ford Aspire 4 door
Team Ford
90 day: 46.75 mpg (US)
(5) A retail dealer, nonretail dealer or wholesale dealer may sell or offer for sale gasoline that is not blended with ethanol if the gasoline is for use in:
(a) An aircraft:
(A) With a supplemental type certificate approved by the Federal Aviation Administration
that allows the aircraft to use gasoline that is intended for use in motor vehicles;
or
(B) Issued a type certificate by an aircraft engine manufacturer that allows the aircraft
(b) An aircraft that has been issued an experimental certificate, described in 14 C.F.R.
21.191, by the Federal Aviation Administration and that is required by the manufacturer¢s
specifications to use gasoline that is intended for use in motor vehicles;
(c) A light-sport aircraft, as defined in 14 C.F.R. 1.1, that is required by the manufacturer
¢s specifications to use gasoline that is intended for use in motor vehicles;
(d) A vintage aircraft, as defined by the Oregon Department of Aviation by rule, that is
required by the manufacturer¢s specifications to use gasoline that is intended for use in
motor vehicles;
(e) An antique vehicle, as defined in ORS 801.125;
(f) A Class I all-terrain vehicle, as defined in ORS 801.190;
(g) A Class III all-terrain vehicle, as defined in ORS 801.194;
(h) A racing activity vehicle, as defined in ORS 801.404;
(i) A snowmobile, as defined in ORS 801.490;
(j) Tools, including but not limited to lawn mowers, leaf blowers and chain saws; or
(k) A watercraft.
That's part of the text of Oregon's ethanol mandate, showing specific exemptions from E10 use. Here's the text of the quoted law here: http://www.leg.state.or.us/08ss1/mea.../sb1079.en.pdf . The other bills are HB 2210 and HB 3400.
However, a local farmer's co-op has no problem filling my car with E0. Just in case, I have gas cans that hold enough to fill my tank.
In Reason we Trust
