Old 07-01-2010, 11:41 AM   #37 (permalink)
jdgFirefly
the dented fly - '96 pontiac firefly
90 day: 52.21 mpg (US)
In the past I've taken apart a die grinder and an air drill, both were all metal except for the vanes which appeared to be graphite so heat shouldn't be a problem.
Also if you have a closed system you could run it at lower than atmospheric pressure so that the water (or whatever) boils at lower temperatures.
