Old 07-01-2010, 10:48 AM   #31 (permalink)
the dented fly - '96 pontiac firefly
90 day: 52.21 mpg (US)
I was serious about using an air conditioning system it is basically the same cycle, with most of the main components of the steam cycle. The parts are available in various sizes at your local salvage yard.
You don't need a turbine to make steam power. Its always been more difficult to manufacture a turbine than a piston motor of the same eff. So i think your more likely succeed with a seam piston rather than a built from scratch DIY turbine. Piston pumps and motors are easy to come by so you have a large selection of sizes and arrangements to chose from. Another option could be to modified air tools. There typically not piston but they are positive displacement (vane motor).
I think that having a positive displacement motor is important in this situation because it is less sensitive to varying loads and will work with a wide range of input pressures. Whereas a turbine needs to be designed for specific operating parameters (not DIY friendly).
What ever you decide I hope it works out for you. Heat recovery is really the last place for big gains in engine eff.
The Following User Says Thank You to jdgFirefly For This Useful Post:
Daox (07-02-2010)
Old 07-01-2010, 11:07 AM   #32 (permalink)
Originally Posted by 320touring View Post
the alternators fitted to the e30 have a sort of fanblade/waterwheel setup on the pulley driven by the belt-could that be modded to produce something similar to the hole solution you've suggested?
Not a bad idea, but I imagine that is there for cooling. If I use it for a turbine, I'm not only stealing that cooling capacity, I'm heating it up! I imagine that ending in a bad way.
Also what consideration haave you given to rusting to the exhaust?
Almost none at this point. Most exhausts are stainless so IMO its not a huge deal. Of course heat transfer through SS is pretty bad, so that is a concern.
Its a great idea, but what effect will the additional sleeve on drag under the car if it hangs lower than the rest of the exhaust, or do you envisage using the setup on the downpipe or manifold?
I don't know where I'd place it yet. Obviously the closer to the engine the more available power and less need to insulate the exhaust. In the environmental aspect of it, you'd not want to rob heat from the CAT though.
Old 07-01-2010, 11:11 AM   #33 (permalink)
Modified air tools, that sounds like a great idea! Just wonder if they can take the heat... I'm not even sure how hot its really gonna get to be honest. I can't imagine there are too many plastic bits inside air tools. Anyone know? I'm thinking a die grinder would be easy to adapt.
Old 07-01-2010, 11:13 AM   #34 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
Here's a drawing of an easy to build impulse turbine. The efficiency isn't great, but that's fine for now.
The alternator wants to spin at 3000-15000 RPM. Alternators are cheap. As long as it doesn't grenade every time you turn off the car, it should be fine without an overspeed brake. Getting it to spin fast enough under load might be an issue, though.
If you determine you need more heat exchanger performance, you many need to go for a bunch of copper tubes inside a 3" diameter exhaust pipe. Actually, I have a book with a chapter or two on analysis of heat exchanger performance, or you may be able to find a concentric tube-in-tube heat exchanger simulator online. But you'll need to know the inlet temperatures of the working fluids and the desired heat flux.
Old 07-01-2010, 11:20 AM   #35 (permalink)
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
i was meaning extend the shaft, than put another one on, and drive that?that way original one still cools the alt?
Could you not route a pipe inside the exhaust to heat the water?
I see what you say about the cat, just depends how much water you want to heat?
Old 07-01-2010, 11:21 AM   #36 (permalink)
Wonderboy's Avatar
The Fruit Bat - '01 Honda Insight
Last 3: 54.26 mpg (US)
Current - '21 Subaru Impreza Wagon
90 day: 34.36 mpg (US)
I like the air tools idea.... any plastic parts may be able to be replaced with fab'd metal. Air tools seem like a great idea for any kind of DIY source for pistons.
Old 07-01-2010, 11:41 AM   #37 (permalink)
In the past I've taken apart a die grinder and an air drill, both were all metal except for the vanes which appeared to be graphite so heat shouldn't be a problem.
Also if you have a closed system you could run it at lower than atmospheric pressure so that the water (or whatever) boils at lower temperatures.
Old 07-01-2010, 11:43 AM   #38 (permalink)
Great news on the air tool materials. Thanks.
I'm not sure how you'd run a closed system. Could you post up a diagram?
Old 07-01-2010, 12:00 PM   #39 (permalink)
Patrick's Avatar
Hot Tamale - '10 Toyota Prius III
Air tool vanes are a plastic composite. They are cooled by the expansion of the compressed air and you have to add lubricating oil periodically or they will seize up. The tools also run at very high rpms, so some sort of gearbox would probably be needed.
Old 07-01-2010, 12:23 PM   #40 (permalink)
klr 650 - '08 kawasaki klr 650
The van - '15 Dodge Grand caravan Avp
what about running copper tubing around the exhaust pipe then to a small turbine that could generate electricity. it would be very cheap and easy enough for any one to do and you could do more than one system since exhaust pipe are generally fairly long. you could have one for your alternator delete and another to add power to the hybrid system.just an idea
Mimicking Gen3 Prius Exhaust Heat Recovery Daox EcoModding Central 77 08-01-2018 04:16 PM
Power and Heat considerations (enclosures, etc) dcb OpenGauge / MPGuino FE computer 22 03-31-2011 08:59 PM
High efficiency ICE (exhaust heat recovery) amnonholland EcoModding Central 21 06-27-2010 01:00 AM
Waste Heat from Exhaust TES111 EcoModding Central 35 11-21-2008 12:31 PM
Steam engine (from exhaust heat) iHero General Efficiency Discussion 23 09-08-2008 12:30 AM
