Old 07-03-2010, 08:58 PM   #82 (permalink)
Patrick
Patrick's Avatar
Hot Tamale - '10 Toyota Prius III
Originally Posted by NiHaoMike View Post
What about modifying lawnmower engines into steam engines?
Well it's been done before and it's pretty easy. All you have to do is take the camshaft out and weld an additional intake and exhaust lobe on it 180 degrees out from the original lobes. Put the camshaft back in and pipe the steam into the intake port. You may have to give it a push to get it started.
