Run a paper filter then replace whenever the minder moves. End of problem. You will be shocked how long you can run a filter with out much restriction.
Most people aren't concerned about restriction, it's mostly filtration. Power hungry guys are usually worried about restriction from the air filter. If you talk about not running a K&N cause they don't filter good enough but you don't change your filters for 60k or 70K+ miles, and you just shake the loose dirt off, how good is the filter filtering even after a good shake? That's just my question.
