Originally Posted by robchalmers
No sure but a will look into it - its only a matter of getting out my trust 26mm deep socket and a 17mm spanner to change 'em and then return them for a bit of a-b-a testing.
need to throw some inj cleaner at my jets anyway because i forgot to do it as part of my service - thanks for the reminder
if they are bosch injectors you should be able to get a table of flow rates off the net. It'd be interesting to see what the difference in rates is.
Have you looked at ultrasonic cleaning for the injectors?relatively cheap compared to new injectors
