Old 07-04-2010, 07:00 AM   #31 (permalink)
Chug - '96 Volkswagon Polo CL
90 day: 49.42 mpg (US)
L'Autre - '03 Renault Megane Sport Tourer Expression
Diesel
90 day: 45.02 mpg (US)
Kind of a Good news - Bad news weekend.
Good news - service done fresh filters and clean oil onboard!
Bad news - found a fuel leak on the 'leak off' pipes on injectors 1 and 2
going to see if my friendly Halfords carries them....doubt it but worth a try
good things come to those who wait, sh*t turns up pretty much instantly
twitter.com/bertchalmers
Old 07-04-2010, 08:28 AM   #32 (permalink)
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
it may be worth trying euro car parts and gsf?
Old 07-04-2010, 10:14 AM   #33 (permalink)
Diesel
online parts says they don't stock them but I'll ring them tomorrow
Old 07-04-2010, 02:21 PM   #34 (permalink)
Diesel
On test run to check bodged fix it got worse so did the honourable thing and called the RAC - took less than 5mins, parts were on the van. done and dusted and no charge! he also said itmay cure any flat spots now that there won't be any air in the system.
Old 07-05-2010, 07:30 AM   #35 (permalink)
Team m8
Hurrah for the RAC- glad they had the stuff to sort it,
Here's to an increase in MPG!
Old 07-06-2010, 03:02 AM   #36 (permalink)
Diesel
hope so!
because I did a water drain on the fuel filter as part of the service, then had to bleed out the system AND then had a fuel leak the latest tank has only managed a pilthingly 53.9MPGuk
Fresh tank now - I'm confident of a long run this time!
The spill pipes are little braided vacuum pipes between the injectors that carry fuel back to the tank return, no real pressure in the system but they still put out a far bit of juice under load....
Old 07-06-2010, 07:50 AM   #37 (permalink)
Team m8
53.9 uk is pretty damn good for that lump- they need trashing to get anywhere
WHat is the duty cycle on the injectors?
I know that on the pug 405 you could put non TD injectors into a TD to increase fuelling and power...
would the reverse work?
IE a TDI injector into your Non TDi?
Old 07-06-2010, 09:58 AM   #38 (permalink)
Diesel
No sure but a will look into it - its only a matter of getting out my trust 26mm deep socket and a 17mm spanner to change 'em and then return them for a bit of a-b-a testing.
need to throw some inj cleaner at my jets anyway because i forgot to do it as part of my service - thanks for the reminder
Old 07-06-2010, 01:41 PM   #39 (permalink)
Team m8
if they are bosch injectors you should be able to get a table of flow rates off the net. It'd be interesting to see what the difference in rates is.
Have you looked at ultrasonic cleaning for the injectors?relatively cheap compared to new injectors
Old 07-06-2010, 04:55 PM   #40 (permalink)
Diesel
I'll look up wht the bosch equivelent injectors are for the TD and D engines and see whats on offer
The little diesel is running sooooo smooth. its amazing loving that 1800rpm-2200 sweetspot!
VW Polo Cup game - Try to be economical master noxman The Lounge 3 04-12-2024 01:33 PM
Spark ignition Diesel engine, AKA your car mechman600 EcoModding Central 28 05-11-2017 07:12 PM
Undertray / belly pan build - VW Golf MK3 1.9 Turbo Diesel sallen Aerodynamics 27 05-21-2011 01:13 PM
Rob's '98 VW Polo Build Thread robchalmers EcoModding Central 36 05-16-2010 05:33 PM
Build Thread Key Postings Index Experiment. TestDrive Forum News & Feedback 7 02-15-2009 08:53 PM
