Old 07-08-2010, 10:45 PM   #11 (permalink)
iplaysdrums
Learning a lot
iplaysdrums's Avatar
Tony - '15 Honda Fit EX
90 day: 40.3 mpg (US)
Lincoln, your post couldn't be more timely. It's 95 degrees, and I just removed the lower grille block. The upper, made of tape, will be harder to remove, but easy to cut holes in if need be. What's a healthy range for coolant temp? The boiling point of water is too high, obviously, and it got dangerously close to that today. What's funny (not funny "ha-ha") about that is the temp. gauge on the dash remained firmly planted in the middle.
