Not so much a enclosure, but more permanent installation.
Took the middle air vent out of a donor car i have. Made a metal plate to mount the mpguino onto. hacked out buttons from a dead dvd recorder(sawing both pcb and front display part). then some 3m carbon vinyl to hold the metal plate to the vent.
(i pics it is attached with hotglue, but it fell off due to heat. So i instead used the stuff body panels are sealed with, and super glue.)
and ofcourse blocked the air to the side it is mounted.
