Old 07-14-2010, 01:21 AM   #5 (permalink)
bestclimb
Smeghead
escort - '99 ford escort sport
90 day: 42.38 mpg (US)
scoobaru - '02 Subaru Forester s
90 day: 28.65 mpg (US)
The injectors is the primary thing. The ECU knows there is a problem with the relay while it is not grounded (no ground no electrical flow so no "magic") so it lights up the check engine light whilst the button is pressed. I don't know if the fuel pump is shut off, but if it is or is not it should not be an issue as the injectors aren't squirting fuel so no fuel needs to flow. Once you let go of your kill switch the ECU no longer sees a problem with the relay, so the check engine light goes out. If the fuel pump was off it will come back on if the pressure is low. When I did mine I hacked into no wires. Just pulled one out of the connector and replaced it with another.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
