its a comon misscomception that its hard to tune an ecu its infact extrmely easy with the right tools the right now how u can do it inside 10 mins u need an eeprom programmer earser one can get here
arlabs google it cant post urls yet (pre obd2)
the only problem is getting the file to witch to tune with....u can try winols but its extremly hard to figure out u almost need to be a rocket sientist or a computer engenieer to figure it out u just stare at a bunch of numbers not knowing what they are.....lol have to goole it cant post urls
or if your lucky enough it will be here alientech-to look in up in goolge
this is the most comon program used by ppl today with popular cars they use drivers u just in put how much power etc
never buy tuneing files of e-bay biggest scam out there also never buy those "power boxs"
Powerboxes are the mother of all evil in this world. I am sure they were developed in a secret facility by satan himself and that is putting it mildly. With chiptuning your change ALL the needed parameters that run your engine. A powerbox just lies to your engine management system, throwing it off balance and feeding your engine the wrong amounts of fuel etc. Very often you will see powerboxes on ebay, which are basically two plastic plugs, a small box and a 5 cent resistor poured into black resin. If you want to get rich quick with an astronomical profit margin you should start selling powerboxes, because the company logo sticker on the outside is the most expensive part of it. Do they give you a noticeable effect? Yes, you will get some more performance, accompanied by a tail of black smoke and an engine that hates you forever. Still want to buy a powerbox? Read this paragraph again.
any questions about it pm me ive been doing ecus and other stuff for quite awile now
