Old 07-15-2010, 06:55 AM   #15 (permalink)
johnf36
Way cool someone else.
A couple of things, the GPs have a under body pan. that can be installed.
I have been running my front air dam almost 3 years along with side skirts.
If you block off the intercooler or at least play with it you can induce a hot air intake. I do this in the winter to keep my MPG up.
I have along with others have picked up a mile to to 2 with vg's on the c pillar.
Also get a filtered oil catch can on the car, it will clean up the fuel mixture.
You can reduce your water temps by using a water wetter.
What oil are you using?
