Old 07-15-2010, 07:12 PM   #168 (permalink)
TomEV
Ford Escort 2.0
TomEV's Avatar
Electricar - '89 Ford Escort LX Hatchback
Possible no-ethanol test for you - Aviation gasoline. It does not contain ethanol Ethanol is prohibited in aviation gasoline, although some aircraft have a cert to run auto gas. Try to get the lowest performance number available so you don't cook a valve.
Couple of problems though - May contain lead (bad for catalytic converter) and is pricey - about $4.50/gl for 110LL. May work if your test vehicle is too old to have a converter.
Here's a link to an airport near Levittown -
Robbinsville Airport
