^woohoo! just about 32!! better than me! I just filled up after my best tank ever and drove 429.6 miles equaling 30.38 mpg tank! Finally hit that 30 mark =) I actually didn't think I was going to hit it because my first 1/3 of a tank had a lot more city driving than I usually do. I also traveled about an hour back and forth in uncomfortable heat leading to my use of a/c, especially when driving a friend around who is used to weather thats 15 degrees lower. I took off my mud flaps and my roof rack, pumped up my tires, and also got an oil change with fully synthetic oil, but I'm still not too sure how much of an impact all those made. I'll see what happens with my next tank-my roof rack was taken off at about 130 miles on the tank, same with tires pumped up. Also, I'll add that Im not doing any coasting in neutral, i'm still iffy about the possibility of harming my transmission.
For my next tank...the goal is still 31, and i'll observe how each of my "mods" affect my overall mpg. I'll check my air filter to see if it needs replacing, and I might even consider removing the back plate of my hood scoop to throw air into the engine area instead of just having it blocked...Do any of you think this would help mpg-wise or am I just better off keeping the back plate on?
Thanks for everyones help! and i'll keep posted on my next fillup (if not sooner
![Wink](/forum/images/smilies/wink.gif)
