Originally Posted by nickdigger
has anyone ever used a MAF or MAP sensor instead of a pitot tube? not to get air speed, but just to measure air flow, generally: e.g., you could compare the values by ducking in/out of a truck's slipstream.
A pitot tube requires ram air AND a static pressure source (dual source) and displays the difference. Very sensitive device measuring small amount of pressure differences.
Aren't MAF and MAP single source sensors? I don't think they have enough resolution for anything beyond their intended purpose. I'm just guessing on this point though.
