I have a 97 Geo Metro 3 cylinder 5 speed. I used the method in post #1 to use a relay to kill the power to the fuel injectors, and using my switch the engine does stop, but the electrical system resets as if I had used the key in the ignition to turn off the vehicle. This interferes with my scangauge. Is there another method for a kill switch that won't reboot the electronics in the 95+ metros?
