Originally Posted by IsaacCarlson
how much power do injectors use anyway? Can't you just put a switch on the main injector ground/power wire?
On my car, the injector has a resistance of 14 ohms. If you do the math, that means it draws about 1 amp. Each injector firing at different times means the draw is not very much. I put a simple microswith on mine and have had no issues with it.
