Old 08-05-2010, 12:29 AM   #87 (permalink)
Bicycle Bob
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
Building Composite Monocoques
>Okay, if you can clarify/correct me on the construction process, here's what I am thinking of doing:
>Cut plywood former sections about every foot -- I can plot full size templates/patterns from DataCAD, and then use spray adhesive to stick 'em to the plywood. I will lay them out in DataCAD to try and fit as many as possible on each sheet. I'd like to be able to test the physical size and layout of the entry method and seat layout etc., before committing to build this car.
---You might want to do a mock-up that includes many structural details, for practise and clarity. Incorporating a mock-up into a finished vehicle would be wonderfully economic of material, but not likely to produce a good part. I saw a boat for sale once, priced about equal to the materials someone had used, but, sadly, they were now worth less than they had been.
Of homebuilt aircraft, 10% are finished by the 1st builder, 10% by the 2nd builder to take over, and 10% by the third. That's for a simple machine, built to plans, with a support community that often teams up.
In choosing a structural foam, you need to run a few numbers, and then, to make sure your foam matches them, you don't use foam-in-place, but buy sheets. Airex is wonderfully tough, with a bit of flex that makes it easy to work with, and several other types could conceivably be heat-formed to fit between plywood formers, but it is probably faster to just cut foam profiles, inside and out, and glue them into a stack that just needs to be sanded down to smooth to form the core of a sandwich. That way you could check the shape for cheap, with options to cut 'n' try. No plywood to complicate things.
For a shape like yours, sheets might also be laid as planks over temporary cardboard templates. The inside seams can be done with fiberglass tape, and the outside ones sanded to a round contour before 'glassing.
>Now, I want to have a composite foam sandwich monocoque, both for strength and for thermal insulation, so do I need to form the inner walls on the inside of the formers first, and then do the outer surface, and then foam in between?
>How do I best form the surface using the formers?
Do I need to use Styrofoam and carve it, or can I use wires and/or screening as a substrate for the composite?
It is okay to leave the plywood in place and have it as part of the structure, or is is better to pull it out and then rejoin the surfaces with spacers/foam?
Is fiberglass significantly less expensive than carbon fiber, and what are the advantages/issues with each?
---Fiberglass is what you learn on, because you can see through a well-made part. An experienced worker can get more strength from 'glass than an amateur can get with carbon. You can look up the current numbers on cost and strength, but what you are really buying is crash safety - toughness - and the aramids or Spectra are best for that. They are tricky to engineer because they are far stronger in tension than compression, and usually used with either glass or carbon compression faces, or a blend. The basic working structural loads can be taken by a sandwich so light you could easily kick through it.
You have to plan to never sand aramid to a smooth finish, and to minimize toxic carbon dust. Carbon is not particularly strong or tough but it is very stiff, and that can upset stress patterns in combinations. J.E. Gordon is a good author to convey a quick, painless grasp of the overall structural issues, and Andy Marshall, among others, has written on how to do things like seat-belt anchors, wheel mounts, and so on for homebuilt aircraft. The Gougeon Bros have some good how-to publications for glass 'n' goo with cellular hydrocarbon cores.
That door arrangement was tried on the (only) Mohs Ostentatienne Opera Sedan.
>I can cut the plywood so that the windows are slightly recessed, to form the lip/flange -- should the windows just be left open and trim the edges, or does it help to cover them over completely and then cut out the openings?
For the main hatch door, and the rear doors, should they be formed as part of the whole outer skin, and then cut out? Or, should the opening be left out of the main piece and then make the doors themselves separately?
---The more details you can carve into the foam or other molds, the less re-work there is to getting done. As these things go, carving up a sandwich part into panels is pretty decent, since they don't warp much without a frame. You can 'glass the cut edges, re-assemble with masking tape, and then stick on some weatherstripping, 'glass over that, and have a decent door jamb. Wax and filler give a hairline seam on the surface with little work. Leaving a little dip near the future edges to allow for that edge wrap is a big time-saver if you want strong, smooth, light parts.
>I want to form a surrounding "beam" around the front and sides of the passenger compartment (which will double as the main air duct into the passenger compartment) -- I hope to have it flush on the inside, and let it into the formers. If the beam was metal, it could be hollow -- can it be made from composite and be hollow?
---Sure. Sometimes we use a temporary foam part to form a tube. You can also get a tube by slitting a cardboard tube to let it bend, and 'glassing over that.
>I'm trying to figure out how to best do the crumple zone in the front: a tubular subframe or a composite structure? Have you seen "crush cones" used between a structural bumper and the firewall/structural passenger cell?
--- Foam makes very good crush zones. Cones are a lot of work - maybe good in production, but not really needed. You can cut foam blocks and add internal 'glass partitions as cones or whatever if you want. That's a good way to get bulkheads to help spread out point loads.
>How does the suspension get attached to the monocoque -- do reinforcing plates need to be embedded, or...?
---Ya gotta calculate the loads, and add layers and/or panels appropriately. Generally, it is handy to build up a strong point with multiple layers of tape, and fan them out to distribute the force to an appropriate perimeter. Sometimes, you need denser foam in some spots. Adding metal can be a lot of hassle to minimize stress concentrations, but sometimes there's no other way. Bolts can be run into cast resin threads in many situations. See "potting."
>I'm hoping to hear from FVT about the size of their battery pack, so I can try and lay out how it will fit inside the floor. I would ideally try and at least have the space for a really big battery pack (50-60kWh!!) so I can get 300-400 mile range. This would be incredible if it could be made to fit!
---Batteries are something that can be tucked away in several places, and sometimes left out for in-town use, if the balance is still OK. But you are more likely to want load levellers, or at least progressive springs. There's more than a bit of art to a good ride.
>I would love to hear whatever your thoughts are! Thanks in advance.
---Vinylester resin can save you a lot of shop time and money compared to epoxy, and is relatively fireproof. No allergies, but it can kill your liver, and it eats unprotected styrofoam.
Are you sure you have the resources and time to get this done while it is still relevant? Money, Time, and Quality - pick any two. Burt Rutan used to offer study plans, and a kit of material sufficient to make a bookend using most of the techniques people would need to use on the aircraft. If the bookend wound up looking neat, or not, was critical data. You can't plug any numbers into your strength calculations until you have tested your own mix of materials, workmanship, and weather.
The name of the game in composites is aligning fibers, balancing stress, and minimizing resin content. Dry bagging can help with all three, and even save time once you learn it. It gives parts as good as any, without the usual wasted layers of absorbent, etc. otherwise used for vacuum bagged parts.
The Following User Says Thank You to Bicycle Bob For This Useful Post:
Cd (12-18-2010)
