Sorry if you thought I was not taking you seriously or poking fun at you, but i feel there may be other factors than the magnets. how you use the care you current conciousness of fuel usage etc could all be a factor - even different brands of gas can do a bit!
From my work with fuels and EM Fields (uni projects) I can find now evidence that the Gasoline is effected by the application of flux. Even it you are talking hi-density neodynium mags you're more likely have upset a sensor or the ECU through EM interference than do anything to the fuel.
Secondly the Carpet theory doesn't really hold much water either sadly sorry. 'using firction in a pipe to 'excite' the fuel would increase the pumping load and likely ruin your pump from overload (magnets post pump) or potentially cavitation fatigue (pre pump).
Sorry to be a kill joy i'm just trying to use the experience I have to give an opinion
good things come to those who wait, sh*t turns up pretty much instantly
twitter.com/bertchalmers
