Old 08-06-2010, 02:49 PM   #7 (permalink)
matthew
The Cuttlefish - '06 VW Golf TDI
I used aluminum bar stock to make 5 brackets that attach to the wheel well using the existing screws. Three of these brackets are mount points for the fairing frame, and two are tabs that hold the flashing flush with the edge of the well. The aero would probably be slightly better if the fairings were flush with the outside of the wheel well rim rather than the inside, but I was willing to sacrifice a bit for aesthetics and simplicity.
The Following 2 Users Say Thank You to matthew For This Useful Post:
ChrstphrR (08-06-2010), COcyclist (10-18-2020)
