Old 08-07-2010, 09:27 AM   #68 (permalink)
EdKiefer
The biggest thing TPS should do is throttle acceleration enrichment , (giving more fuel when you hit the gas).
You sure the TPS is changing timing and not map signal (more load), to make sure or test what TPS does on its own try an remove TPS from throttlebody. Then you have move TPS signal voltage separate from throttle to monitor changes .
