Originally Posted by AeroModder
Start by inflating the tires to 45 PSI and blocking the upper grille, if you haven't already. That's an easy place to start.
They have been at 42-44 psi for over a year.
I had both a upper and lower grill block on over the winter, but as it warmed up I removed them so the fan would not run all the time. Should I still to the upper grill bock and let the fan run some?
Last winters set up.
