Old 08-08-2010, 01:50 PM   #11 (permalink)
XJguy
XJguy's Avatar
Originally Posted by BLSTIC View Post
Oh I should have mentioned my driving during testing covered a very wide range. Hot, cold, wet, dry, city and country (and any combination of those). And a couple of mountain ranges too.
And just for good measure, some 150kph cruising in 35*c weather...
That may be so, but when they make a car they design it so that say for example should you choose to live in the Mojave desert and drive around all day, your car will keep going and wont have its components break down due to thermal failure or parts start melting. Not just take a drive one afternoon. Even so, some otherwise well designed cars suffer with all their guts exposed. Take for example the earlier v12 S-class Benzes, great cars, great mechanicals...but they generate so much heat that over time they would literally melt all the plastic components underhood if you stepped on it regularly or drive around all day....this is why today they are not the most desirable of cars even if you do find one still running.
What I am saying is there are no free lunches, yes you might gain efficiency in the short term, but unless you are engineering in ways to protect and cool vital components, you are shortening the life of your car or the rate at which parts breakdown....it does not always happen overnight.
The Following User Says Thank You to XJguy For This Useful Post:
MrMiata (11-13-2010)
