Old 08-08-2010, 03:29 PM   #11 (permalink)
steve-o
skate - '92 Toyota Paseo
90 day: 48.56 mpg (US)
Originally Posted by Gasoline Fumes View Post
I have no idea what the intake temp is, but it should be pretty warm already. I got rid of all of the tubing connected to the airbox, so it's sucking in underhood air. Which should be pretty hot in summer with most of the grill blocked off.
Just a thought on the WAI thing. even if you are pulling air from under the hood with the grill block it is taking a good while for the air to warm up. if you can pull air from an air box off the exhaust manifold you will get warm air quicker...
The Following User Says Thank You to steve-o For This Useful Post:
Gasoline Fumes (08-09-2010)
