Originally Posted by ecofreak
If you can remove the rear spoiler thing, you can use the exposed brackets to mount your kammback. Make sure the roof of the kammback is angled at 15 degrees down from your roofline, and make sure the bottom lip extends to your bumper. Make sure it rest flush against you rear panels.
The rear spoiler thing is where I will mount the top, what is this flush on the side panels?
you are saying to extend it past the bumper? that is only about 18". is more better?
