Originally Posted by Phantom
A few ways that magnets could/can help is:
Place one on drain pan by the drain plug and remove just before draining the oil. This can keep magnetic metal shavings from moving through the engine to help keep wear down.
That isn't a bad idea at all. A large CB attenna magnet should do the job. Of course, this is also assuming my aluminum engine has cast iron sleeves
